Engine Management Light Flashing - MeganeSport.net
    + Reply to Thread
    Results 1 to 10 of 10
    Thread: Engine Management Light Flashing
      Feb 2010
      Gateshead
      Ultra Blue 225 RS Stage 1
      Default Engine Management Light Flashing
      Hi Everyone
      I tried a search but I am useless at using that function effectively on all forums and this search function seems particularly tough!
      This morning when driving to work after about 30 seconds of driving the engine management light flashed on about 10 times then went off and staid off for the other 20 minutes of driving in.
      I had some Hankooks fitted last night - could it be a tyre pressure issue? Or at least a problem with the fragile tyre pressure sensors??
      Thanks, Duke
      Mar 2010
      Kandahar Air Base
      WRX STI - Prodrive
      Missfire, Coil pack or Injector
      Mine did this a couple of times but it hasn't came back since
      Feb 2010
      Gateshead
      ahh thanks mate, I have noticed its a little bit lumpy on idle too which ties up with your description
      is yours running ok now if you have done nothing about it?
    4. #4
      Mar 2010
      Kandahar Air Base
      WRX STI - Prodrive
      100% fine, if your concerned book it into Reno for a Diag and they may replace the offending Coil/Injector
    5. #5
      Feb 2010
      Gateshead
      Thanks for the quick replies mate, spot on!
      Sounds as though i may be leaving it if the light stays off seeing as though yours has been fine.
      Just to be a pain - you dont know rough replacement costs for each?
    6. #6
      Mar 2010
      Kandahar Air Base
      WRX STI - Prodrive
      Haven't a clue i asked about the Coil and was told they were around £45 as for injectors no idea ! if i were to replace the injectors id uprate them so i could get more out of a Stage 2
    7. #7
      Feb 2010
      Gateshead
      Cheers dude - think i will buy a coil pack and work my way till i find the broken one
    8. #8
      Apr 2007
      Chelmsford
      Black R26
      If you have a ODB port scanner it should give you a code, then google it and it'll tell if a fault is registered. IF it is a coil it will tell you which piston too
    9. #9
      Feb 2010
      Gateshead
      Ooo that sounds handy wish I had one may have to invest I believe ktec sell them don't they
    10. #10
      Mar 2010
      Kandahar Air Base
      WRX STI - Prodrive
      Id invest in an RSTuner from Henk had one for my clio but sold it on when i picked up an Ek9 wished id kept it now though !
    + Reply to Thread
