I tried a search but I am useless at using that function effectively on all forums and this search function seems particularly tough!
This morning when driving to work after about 30 seconds of driving the engine management light flashed on about 10 times then went off and staid off for the other 20 minutes of driving in.
I had some Hankooks fitted last night - could it be a tyre pressure issue? Or at least a problem with the fragile tyre pressure sensors??
Haven't a clue i asked about the Coil and was told they were around £45 as for injectors no idea ! if i were to replace the injectors id uprate them so i could get more out of a Stage 2
If you have a ODB port scanner it should give you a code, then google it and it'll tell if a fault is registered. IF it is a coil it will tell you which piston too
Id invest in an RSTuner from Henk had one for my clio but sold it on when i picked up an Ek9 wished id kept it now though !
Related Threads
Megane Sport Forum
792K posts
17.7K members
Since 2006
A forum community dedicated to Megane owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
