Water in the footwell - qwick fix - MeganeSport.net
    + Reply to Thread
    Page 1 of 2
    1 2 LastLast
    Results 1 to 10 of 19
    Thread: Water in the footwell - qwick fix
      Jan 2011
      Essex
      Renault Megane 225 cup
      Default Water in the footwell - qwick fix
      Ive got the good old water in the footwell.
      Ive seen the below guide which is very good but it wouldn't take me 8.5 hrs more like 3 days.
      Is there a quick fix for this maybe just clearing the drains and letting the car dry natuarrly?
      and what is the easiest way to clean the drains?
      http://www.meganesport.net/community...footwell-leaks
      Oct 2010
      Belfast/Huddersfield
      Megane
      When I cleaned mine I use Mr Mussel Drain Unblocker and a piece of wire, to poke any crap through.
      There isn't really a quick method, as the sound deadening will more than likely be soaked though. It will start to smell if not dried properly.
      Lemon's Avatar
      Lemon is offline Meganesport Area Rep - South West
      Nov 2006
      Bristol
      Blue 225 stg 1 and 172
      As above it won't dry naturely I've tried this and it will smell horrible
    4. #4
      Aug 2007
      Nuneaton
      Audi S3
      Rubber backed carpet, keeps the water out but keeps it in just as well.
    5. #5
      Jan 2011
      Essex
      Dam-it what a pain!
      Looks like im going to have to take a couple of days off to fix this one.
    6. #6
      May 2011
      Peterborough
      Boooosted R26
      Depends how far back the water is, I unblocked and then lifted the carpet up from the side (removed compartments) and just cut out the foam from under the carpet and dried with blue roll and heat gun over a period off 2 weeks.
      Smell has gone now and it's all dry
    7. #7
      Jun 2010
      Derbyshire
      Megane r26
      The drain holes under my scuttle panel where completely blocked with leaves and gunk, luckily (by complete chance) I found the issue before any damage was caused...
      There was a good 2L of water collected in the scuttle area splashing around!
    8. #8
      Jan 2011
      Essex
      If I turn the radio off and take a couple of corners I can hear the water behind the dash somewhere.
      Some is getting through cos when I leave the car stationary it looks like it's wet it's self.
    9. #9
      Jan 2011
      Essex
      Quote Originally Posted by losi_8_boy View Post
      Im gona give this a try cheers!
    10. #10
      Jan 2009
      London
      Meg R26 White/Black
      Quote Originally Posted by Gray View Post
      where is this scuttle panel... i discovered a load of water in my driver side foot well today.. on ly in the drivers side at the mo...
    + Reply to Thread
    Page 1 of 2
    1 2 LastLast
