oil change best oil and filter please - MeganeSport.net
    + Reply to Thread
    Results 1 to 8 of 8
    Thread: oil change best oil and filter please
      Sep 2011
      essex
      megane rs 250
      Default oil change best oil and filter please
      hi all
      can someone tell me the b est oil and oil filter to get please :-)
      im guessing synthetic, can you give me a link to where to get it if poss as well
      and how much oil do i need? thanks!
      Mar 2010
      Mid Wales
      2006 Megane 225
      See opie oils on here. In the traders section. Genuine filter, I use Fuchs Titan.
      6 litres will do you, can keep some for topping up then
      Dec 2009
      Cardiff
      250+Cup / Caterham 7
      If you want to keep your warrantee intact (just for the sake of Renault not kicking off if something bad did happen), make sure you get the Renault approved stuff. While the Fuchs stuff is no doubt better, they don't have the Renault sign off.
      I used Castrol Edge (Fully Synthetic) 5W40 on my last oil change and it's been fine, it's definately looking a lot better than the Elf stuff that was in there from new.
    5. #4
      May 2011
      leicestershire
      RS megane 250
      I use fuchs titan pro race s 5w40 its good stuff engine is noticable quieter since using it , it also exeeds all renault specs so no probs with warrentee
    6. #5
      Sep 2011
      essex
      megane rs 250
      many thanks for replies!
    7. #6
      Dec 2009
      Cardiff
      Quote Originally Posted by bananaRS View Post
      But it doesn't have the Renault RN0710 / Renault RN0700 approval. It may exceed them in every single way, but Renault haven't signed it off.
    8. #7
      Sep 2011
      essex
      megane rs 250
      yup i got the catrol edge one which does meet there approval, thanks for help i would never have known
    9. #8
      Sep 2010
      wilts
      black RS250 cup,loaded
      If they check then then they will refuse any work on it Engine/Turbo i have had this in the past trust me its not worth it
      Shell Helix for me if its good enough for the Ferrari 430/458 then thats good enough for my Meg
    + Reply to Thread
