random multiple cylinder misfire problems!!! help - MeganeSport.net
    + Reply to Thread
    Page 3 of 3
    FirstFirst 1 2 3
    Results 21 to 26 of 26
    Thread: random multiple cylinder misfire problems!!! help
      Feb 2012
      hastings uk
      megane II R26 f1 Team
      I was in 4th doing 40 mph . No stress on the engine, whats a BMC CDA?
      I hope the injectors sort this.
    2. #22
      Apr 2011
      north west
      It will be the injectors. If the toxic fume light flashes for a while then the car will go into limp mode.
    3. #23
      Mar 2012
      inverness
      Megane F1
      See im having the same problem, rough idle, loss of power, not all the time, changes its mind all the time, had renault look at it yesterday and they couldnt see any codes, but when i got home i was getting p0300 again.
      Havent had any messgaes on dash as of yet, just engine lgiht flashing.
      Let us know how you get on bud!
    4. #24
      Feb 2012
      hastings uk
      fitted the injectors today !!
      jobs a gooden, thank god,
      cheers for the advice people.
    5. #25
      Jan 2012
      Kent
      :-) I am glad it is all sorted, enjoy it
    6. #26
      Jul 2013
      uk
      R26
      Hi, I have a problem car during quiet ride about 2800 rpm throws an error check , which flashes and then after a while, check esp appears , and the car loses power and begins to walk on 3 cylinders already installed a new spark plugs, ignition coil and one injector therefore, I once worked out that misfire 4 cylinder , recently I had changed the lclutch and dual-mass , but a few days after the change was ok, errors that appear like a flashing Check DF436 abnormal combustion process , DF109 lack of fuel combustion minutes , DF457 flywheel rim ,
      These are temporary errors that August cancel , anyone have any idea what is it?
    + Reply to Thread
    Page 3 of 3
    FirstFirst 1 2 3
