megane rs225 swivel hub bearing replacement - MeganeSport.net
    Results 1 to 2 of 2
    Thread: megane rs225 swivel hub bearing replacement
      Feb 2016
      Leigh/Wigan
      black 2005 megane rs225
      Default megane rs225 swivel hub bearing replacement
      Hi Meganers
      Can anybody with a Megane RS 2005 mk2 who as replaced the bottom swivel hub bearing without buying the whole unit tell me where I can source a bearing and seal from please.
      I know Renault only supply the whole or complete hub.
      Ideally I want to take of the swivel hub assembly and have a bearing at hand to replace the old one rather than having to measure up the old bearing and then order a replacement.
      Any info/input would be greatly appreciated.
      Mar 2017
      Lithuania
      '04 Renault Megane RS 225
      Hey,
      I have the very same problem at the moment. I have ordered replacement bearings and read the guide on how to replace them. I'm still waiting for the part to arrive, so all I can give You is the where to order it and the guide.
      One question though. What symptoms do You feel when driving which You attribute to the bearing fault in question? I just want to be sure I have the same and that the bearings are the only problem.
      Order here: turborenault.co.uk/shop/product/megane-225r26-hublower-swivel-bearing/
      Replacement guide: turborenault.co.uk/t38970/
