Help! Turbocharger removal - MeganeSport.net
    Results 1 to 3 of 3
    Thread: Help! Turbocharger removal
      Mar 2017
      staffordshire
      Megane 225
      Default Help! Turbocharger removal
      Hi, the turbocharger has let go on my daily driver 225- dumped oil into the inlet side of the engine, soaked the spark plugs etc.
      I have removed the hard pipe from the turbo and oil literally poured out, so its definitely the turbo unit
      I now have a replacement unit and have begun the process of trying to remove the old unit but obviously space is tight to say the least!
      Does anyone have any advice as to removal with engine still in place- any advice is greatly appreciated.
      Aug 2017
      Leicester
      I removed mine by sliding it under the windscreen over to the right hand side of the engine bay as you look in, was a lot to take off but got it done in about 3-4 hours all back together
      Sent from my iPhone using Tapatalk
      Sep 2017
      Palma de Mallorca
      Take out the plastic above the windscreen and you can do it.
