going from normal to sports mode is no longer making any much difference. before this happened switching from normal to sport used to give a much better throttle response, now the difference is barely noticeable. when put on scanner, the results showed no fault.
any idea what could be happening?
note: everything was working properly before i had the ac compressor changed, and the abs sensors (ones attached to the wheels) fixed.
