R26 Spring Rates - MeganeSport.net
    Page 2 of 5 FirstFirst 1234 ... LastLast
    Results 11 to 20 of 45
    Thread: R26 Spring Rates
      Mar 2008
      Lancashire
      R26
      I have took this from the Gaz coilover thread
      The spring rate was the technical area that took the most time to develop. After trying numerous different set ups and ratios across a range of UK circuits we ended up using 425 Lbs on the front and a dual rated spring on the rear. The R26R has 220Lbs on the front and rear
    2. #12
      Apr 2007
      Cardiff
      Silver, Carbon'd up R26
      R26 rear springs are progressive too mate
    3. #13
      Aug 2006
      Nth Lincs/Manchester
      To Be Continued..........
      Seemed low to me also Tim. Figures came from Eibach this afternoon.
      I guess it needs to be factored in that some are linear and some are progressive so some of the progressive types may be stating the maximum spring rate, whereas the actual part of the spring used in general day to day driving has a much lower spring rate. I guess this is the case when comparing the progressive R26 springs with the linear eibachs?
    5. #14
      Apr 2007
      Cardiff
      I wonder what ratings the prima racing springs have?
    6. #15
      Aug 2006
      Quote Originally Posted by david h View Post
      R26R's aren't 220lb's. At least not the maximum spring rate. Will amend Gaz rear value.
    7. #16
      Aug 2006
      Quote Originally Posted by caymanR26 View Post
      Duly amended.
    8. #17
      Aug 2006
      Looking at this pic, it's the front spring on the Gaz which is dual rated (progressive). The springs in the pics are next to the wrong dampers respectively.
    9. #18
      Aug 2006
      Unsure matey. I'll see what i can find out.
    10. #19
      Apr 2007
      Cardiff
      Those rears are linear mate
    11. #20
      Aug 2006
      Those rears are liners mate
      Yep, have updated the main post.
