LSD for 225 - MeganeSport.net
    Page 3 of 4 FirstFirst 1234 LastLast
    Results 21 to 30 of 31
    Thread: LSD for 225
      i have had one for three years now and its a big help, but it will come down to how grippy ur rubber is, and what power ur runing, if ur cornering in the right speed and u WOT it it will pull to the inside and tighten the corner, to fast it will understeer still no miracals.
    2. #22
      Jun 2009
      holywell
      how can you check if the lsd is still working correctly
    3. #23
      Apr 2011
      Essex
      LY R26
      www.demon-tweeks.com have the quaife atb lsd for sale for the 225 its £702 incluiding vat i think...
    4. #24
      Aug 2010
      Staffs / Ireland
      my08 STI/106 S1 Rallye TB
      find a good roundabout, traction control off, go round and give it sum youll feel the steering wheel pulling and the car will pull you round tightish to the curb as opposed to under steering rite across the road
    5. #25
      Jan 2010
      Wrexham, North Wales
      LY STG 4 RS Tuned R26
      It still works with traction control on thou doesn't it?
    6. #26
      Aug 2010
      Staffs / Ireland
      Yeah but the traction can cut in to soon as you get a bit of slip, kinda defeats the poin when the power ur tryin to put down gets cut.
    7. #27
      Jun 2007
      so you'll need to run with the tc cut on ff models if you wanted the LSD to operate? i have a cut off already installed.
    8. #28
      Aug 2010
      Staffs / Ireland
      erm itl still work i guess, just from what ive found on the track the TC can interrupt before the diff has chance to work its magic if that make sense, the minute it senses a bita slip it cuts in.
    9. #29
      Jun 2009
      holywell
      aint there any other way without tryin it out on the road no way of jacking car up and spinning wheels as i thought they are both suppose to turn a certain way
    10. #30
      Sep 2016
      Turkey
      Megane RS 225
      Has anybody got the info about the "bearing and seal referance number" of Renault in order to renew them while installing Quaife ATB into Megane 225 gearbox ?
