Dump Valve fitting guide - MeganeSport.net
    Page 3 of 4 FirstFirst 1234 LastLast
    Results 21 to 30 of 36
    Thread: Dump Valve fitting guide
      Oct 2009
      The Only Way's Essex
      Charged VX
      Quote Originally Posted by nicholas221078 View Post
      im thinking about getting a forge dump valve,the gen ones off ebay,ive looked at the fitting guide on here looks simple enough,but whats theis about a blanking plate?
      cheers
      The forge dumpvalve comes with a blanking plate which replaces the valve on the turbo! Its best to change it for the best performance out of the dumpvalve! Also it could loose boost if you have both on at the same time!
    2. #22
      Dec 2009
      wakefield
      blue 225-gsxr100k6-ugly van
      Quote Originally Posted by Artic Monkey View Post
      sorry for being dumb but if i change it for best performance,wont loosing boost kill performance too?
      unless ive missread
    3. #23
      Oct 2009
      Charged VX
      unless ive missread
      The turbo makes the boost so the more the better! If you loose boost then it means the power from the turbo will die off a lot quicker!
      Fitting the blanking plate will let the turbo hold the boost better and will only release threw the dump valve! It just makes things more efficient
    5. #24
      Dec 2009
      wakefield
      sorry arctic just posted on other thread so you have answered my q,
      cheers matey
    6. #25
      Nov 2010
      West Scotland
      Megane 225
      Any tips on getting the old valve off and fitting the blanking plate??? its annoying the hell out of me..
      cheers
      D
    7. #26
      Mar 2010
      Kandahar Air Base
      WRX STI - Prodrive
      Cut a small bit off the bottom hole of the blanking plate so you can screw the bottom bolt in by hand sit the blanking plate on then tighten it all up
    8. #27
      Aug 2008
      Doncaster
      Red R26
      remove the intake pipe from the airbox, you will be amazed at how much room it frees up. was the only way i could get to the bottom bolt.
    9. #28
      Jul 2011
      leamington
      GW R26
      I'm not looking forward to fitting this blanking plate lol oh well it must be done lol
    10. #29
      Mar 2010
      Barnsley
      225 F1 No.226
      what tools are people using to remove the bottom bolt on the blanking plate, its drivin me insane!
    11. #30
      May 2012
      Carlisle, Cumbria
      265 CUP + VW Touareg
      I used a 10mm socket on a swivel joint on a long extension all on a 1/2" drive. I would have preferred to use 1/4" drive but I didn't have a swivel or extension in that size.
