Front RS 225/R26 wishbones - MeganeSport.net
    Page 2 of 3 FirstFirst 123 LastLast
    Results 11 to 20 of 29
    Thread: Front RS 225/R26 wishbones
      Jul 2007
      Derbyshire
      ph1 225 5dr black.
      Yep the nearside is £144 from ads.
      I'm just waiting for mine.
    2. #12
      Jun 2012
      Lancashire
      Megane RS 225 ™
      Lol! In other words the rest of your suspension is corroding faster than the wishbones
      KTec are selling these wishbones for much less than what the previous thread quoted from Reno. Was quite surprised as they usually add a few quid to things that they supply.
    3. #13
      Jun 2012
      Lancashire
      Megane RS 225 ™
      http://www.k-tecracing.com/show_prod...=4646&appid=12
      Not sure why the rightbhand side so so much cheaper than the left?! They are the same symetrical pieces of metal! Lol
    5. #14
      Jul 2010
      chesterfield
      MEGANE 309
      One has a headlight leveller bracket
      Sent via brick through window
    6. #15
      Jun 2012
      Lancashire
      Megane RS 225 ™
      Ah ha! So the pictures aren't of actual parts then. I might just strip my entire hub tomorrow if the weather is ok and take picture of everything!
      While you're hear Mark, how do you find/check the other engine/box mounts?
    7. #16
      Aug 2008
      South Wales
      have you changed the top engine mount Lee by the air con pipe? theres also a stabaliser bar there that is worn on mine which im replacing.
      yes i have had two sets of springs snap on me now (second set had done 29k already), seems they corrode quite fast. as for the track rods/ends they do wear fast. got non gen at the moment, and they aren't a great fit in my opinion so just upgrading all to oem renault and hopefully get a bit longer out of them. i'd rrplace the wishbones now but i've already spent about £800 on parts this month
    8. #17
      Jun 2012
      Lancashire
      Megane RS 225 ™
      Hi Tom, I haven't changed any mounts yet but will definitely be doing the top one first as it's the most common to go. I've been told by Aarons Autos that the gearbox mount was worn when he did my bearings, but I don't know for sure where / how to locate it?
      I had a spring snap on the front, luckily they are covered in a thick protective sleeve so it never caused too much of an issue. £800 in a month on parts is crazy isn't it, these cars eat metal! lol
    9. #18
      Jul 2010
      chesterfield
      MEGANE 309
      If the main one has gone then the chances are the others will be getting ready, battery out to do the box mount I'm afraid
    10. #19
      Aug 2008
      South Wales
      can definitely recommend doing the top one, that made a huge difference for me. haven't changed my box mount yet. took loads of pics whilst doing the top mount if you need any, going to throw a guide together with the instructions lemon gave me when i did it
    11. #20
      Jun 2012
      Lancashire
      Megane RS 225 ™
      Quote Originally Posted by Tom J View Post
      That would be a great help Tom I think the top mount can be picked up for around 50 odd quid, so it's something I could justify doing while the car sits still. Any help is better than nothing.
      Mark, how long/big of a job is the box mount, would it be easy for you to do when you do my clutch?
