Creaky window seals - MeganeSport.net
    Page 1 of 2 12 LastLast
    Results 1 to 10 of 20
    Thread: Creaky window seals
      Jun 2011
      Colchester
      RS 250 Full fat & Cup
      Default Creaky window seals
      I know this has been talked about before but my drivers side and to be honest passenger side window seal is creaking like mad and driving me nuts ! Tried all sorts of spray on it to try and cure it! Warranty runs out next month thought I would mention to them as apparently creaks are not covered but surely if its that bad they should do something about it?! (I know this is Renault we are taking about)
      Anyone any ideas would be much appreciated !!?
      Dec 2012
      Chichester
      Clio V6 255 & 172 Ph1
      I'm so glad this isn't just me! My 265 is only on 1800 miles (about 5 weeks old) and my driver side creaks like mad.
      I discovered droppping the window a bit stops it, so figured it was the window seal causing the noise, but this obviously isn't a solution.
      Watching this thread with baited breath.
      May 2012
      Cumbria
      Megane Trouphy
      Warranty, get it booked in
    5. #4
      Mar 2010
      kent
      R26.R
      i used to spray some quick detailer on the seals and it stopped them creaking for a while.
    6. #5
      Mar 2013
      Edinburgh
      R26 No.0105
      Whereabouts did you spray it, just on the rubber seal the window goes into?
    7. #6
      Mar 2010
      kent
      R26.R
      Wind the window down and spray wherever the glass touches the seals, worked for me.
    8. #7
      Mar 2012
      Leeds area
      265 Trophy & Clio 200
      i use swissvax seal feed. Took an application daily for 3 or 4 days for it to stop.
    9. #8
      Jun 2011
      Colchester
      Did that fix it? I just know renault will say its not covered as per !
      Quote Originally Posted by Mentalpen View Post
    10. #9
      Mar 2013
      Edinburgh
      R26 No.0105
      I'm going to try 1z Gummi Pflege as it's a fraction of the cost of Swissvax and is a rubber door seal conditioner/restorer too.
    11. #10
      Apr 2008
      Germany
      RStuning Stage II R26
      is it definitely coming from the window seals ?
      I remember hunting for a noise on the R26 which I thought was a door panel and it ended up being the door locks.
