Iobd2 - MeganeSport.net
Google Search
    Results 1 to 6 of 6
    Thread: Iobd2
      Jan 2011
      gloucester
      06 ph2 megane 225 lux
      Default Iobd2
      Unsure if this is the right place for this and am sry if it's not ! Iv done a search and nothing came up for the question I have ! Iv seen on iTunes iobd2 for reading the error codes etc on the meg ! But where can I get the hardware to use this system ? Iv looked on there web site and still unsure . Could some one point me in the right direction on where to get one ! Thanks daz
    2. #2
      Mar 2012
      Leeds area
      265 Trophy & Clio 200
      apple only sign a few obd scanner chips such as GoPoint BT1 or GL1 or a wifi linked one such as obdlink or kiwiwifi
      i know some have limited success with Chinese copies of the wifi versions but i've not tried them. I use a jailbroken iphone and add Roqy BT4 via cidia (£4ish) and them connect via that which opens up none BT signed chips of which i use a ELM327 obd BT scanner running V1.5.
      I works fine with various apps.
    3. #3
      Mar 2012
      Leicester
      R26-RS
      £35 eBay. Kiwi copy
    4. Remove Advertisements
      MeganeSport.net
      Advertisements
    5. #4
      Jan 2011
      gloucester
      Mental that went right over my head lol !
    6. #5
      Mar 2012
      Leeds area
      In short, your iPhone will only connect with apple approved accessories.
      Some wifi connected copies are said to work but with mixed results.
      But you can also jailbreak your device and add a app that allows you to connected to Bluetooth none approved devices.
    7. #6
      Aug 2015
      California, U.S.A
      2006 Mégane RS 225
