Gearbox clonking - MeganeSport.net
    Results 1 to 7 of 7
    Thread: Gearbox clonking
      Jun 2010
      Denmark
      RS300
      Default Gearbox clonking
      So, I'm having this gearbox clonking noise for some time now and I have no idea why this is happening. I'll try to explain what the sound actually is:
      The clack noise only appears when I lift-off from throttle, so that I have engine-braking, or gently accelerate after coasting. This clack sound is only the initial 1/10 second when the engine is either pushing the gearbox, or "engine braking". Gently bouncing the accelerator gives the hardest clonking noise, and it's most noticable a lower engine rpm speeds. I'm convinced its gear/clutch related, as the slightest accelerator bounce will set it off, I doubt the engine/gearbox mounts can even feel it.
      To me, it feels like the DMF is acting like it has its springs missing and it's just rotating the flywheel freely to each end of travel, then hitting the stops and going "clack", which is why it also does it when you lift your foot off the accelerator.
      My clutch does however need replacing, as it has started slipping recently. The clonk noise however, was there before this even happened. Does anyone know what this clonking noise is caused by? I am suspecting perhaps the flywheel, or could it even be the enginemounts / gearbox mounts? My car currently has 40k miles done.
      I have read a similar story to this on another car, and he needed its differential replaced, as the noise stayed after replacing clutch/flywheel/mounts etc.
      Jul 2010
      chesterfield
      MEGANE 309
      Sounds like the dmf is fooked, it'll have a lot of play causing the clunking noise
      Sent via brick through window
      Aug 2012
      Liverpool
      RS 250 FF + Cup + Recaro
      If your clutch needs doing anyway then it is the perfect opportunity to get the DMF checked at the same time. You'd want to replace the DMF anyway so it really doesn't matter if the DMF is knackered or not, but would put your mind at rest that there wasn't some thing else going on.
    5. #4
      Sep 2011
      Essex
      265 Trophy / 225 Lux
      Did you ever cure this?
    6. #5
      Aug 2012
      Manchester
      250 cup.FF
      It sounds to me like the Cambelt bearings. Had a new belt and water pump under warranty.
      Have a look at this thread,
      https://www.meganesport.net/community...=engine+rattle
      Elliott.
    7. #6
      Aug 2007
      Nuneaton
      Audi S3
      That will be nothing to do with the cambelt what-so-ever. As he'd already deduced shot DMF, you can get a perfectly healthy one to make the same noise under certain conditions.
    8. #7
      Apr 2015
      Sydney
      RS265 RB7
      mine does exactly the same thing. Dealer says it's diff noise & "it's normal for our cars".
      Did you end up replacing the DMF & cure the noise?
