Speed Camera Detectors - MeganeSport.net
    Page 2 of 3 FirstFirst 123 LastLast
    Results 11 to 20 of 27
    Thread: Speed Camera Detectors
      Jun 2010
      N.Wales
      Black R300 + FQ340.
      Right, As you probably know theres different types of cameras. Main type are the big yellow fixed ones on the side of the road - gatso's. You can use most GPS devices to notify you of these. Satnavs, dash mounted gps systems etc. These are the easier ones to find.
      The mobile ones use laser. As they just turn up anywhere they are much harder to spot. You can mark usual locations on your satnav or other GPS device although the problem then is it'll notify you of the point even when the camera isn't there. To beat laser you've only really one option - a diffuser. Usually 2 heads that you install to the front of your car which when they pick up the laser from the gun they pulse back another laser to stop the gun getting a lock on you. You get an audiable warning, slow down and shut off the diffuser allowing the opperator of the laser gun to then get a lock on you.
      Be carefull tho as these aren't exaclty legal. Saying that alot open garage doors or you can get one that is a parking sensor and at the flick of a switch changes mode. Very handy to have that feature if asked Some will produce jam codes on the gun which again you don't want or you'll be getting a tug regardless what speed they clock you at!
      Jamming them isn't all that easy tho. You can get off axis shots, sunlight interfearance etc all of which will reduce the effectivness of the diffuser. Head on long range shots are the easiest to diffuse. The closer you get to the gun, the harder it is to diffuse.
      Laser is deadly. It produces very little scatter so a dash mounted detector like a valentine one won't help in the majority of cases either.
      If anyone wants a top diffuser that won't throw any jam codes up and has the parking assistant feature drop me a PM. I've one for sale brand new.
    2. #12
      May 2012
      Cumbria
      Megane Trouphy
      Using a jammer is perverting the course of justice, which you go to jail for. If the camera van can't get a fix on you they mark the DVD and you will get a visit. The camera van has a DVD running all the time, it is a camera it records, if you take your hands off the steering wheel to give the van the two finger V salute you will be done for dangerous driving. The only way to avoid these, is not to speed, otherwise take the punishment, for speeding as a jammer brings a higher sentence.
      On the other hand a camera detector can be really useful, especially in a strange place, where you are unsure of your environment and it is easy to get caught out looking for places, concentrating on other things that can cause you to loose track of the speed limit.
      RoadAngel Gem is my choice, it only has to save you once to pay for itself
    3. #13
      Jun 2012
      Lancashire
      Megane RS 225 ™
      Thanks for that write up, makes a lot more sense now. I suppose the only other option is never break a speed limit.
    5. #14
      Mar 2007
      Kent
      RS 250 ;-)
      Another one not mentioned. device is called "coyote" it does all the things you get with a tonton etc but it also have a feature where you can report mobile camera and once reported you update the people that are following you.
      So if bob report a mobile speed trap on his coyote on the m25 at j7 and I happen to be driving on the m25 but I'm at j5/j6 then my coyote will tell me that I should be careful at j7 due to a possible mobile speed trap! So you basically helping each other out. Obviously the more people own it the better and to be fair it doesn't really work here due to not many people owning one but in France loads and I mean loads of people have one and work a treat. Only down side is that there is a yearly subscription.
    6. #15
      Jul 2011
      wolverhampton
      meg 250
      Police dont need to be parked up either, ive been done last week, driving past a police car in opposite directions. Couldnt beleive it myself
    7. #16
      Mar 2007
      Kent
      RS 250 ;-)
      Quote Originally Posted by ryan197 View Post
      Now that's a weird one. How did they get an accurate reading?
    8. #17
      Jun 2012
      Lancashire
      Megane RS 225 ™
      Sounds like some very sophisticated equipment they had! Must have taken into account their precise speed inorder to measure how fast your vehicle was moving towards them. Or, it just guessed....
    9. #18
      Oct 2010
      Cambridge
      sold :'( Porker hunting
      My dad used to use a Valentine 1, although doesn't have it fitted anymore.
      It would give you sufficient advanced warning of any radar devices ahead that you could be under the speed limit before they were in line of sight, tell you how many devices there were and their (rough) position relative to you. It also picked up automatic doors for pretty much every shop you visited and military / airport radar systems.
      It would pick up laser detectors (the noise it made for these was a bit of a shock - compared to a normal K-band radar), but tbh if it knew you were in a laser zone, the laser gun had your speed.
      They are fairly expensive little devices, if one of the best on the market and currently illegal in the UK.
    10. #19
      Jun 2010
      N.Wales
      Black R300 + FQ340.
      Quote Originally Posted by Womble View Post
      That is true. However, Your not jamming the gun entirely. You get tragetted, te diffuser gives you an audiable warning, You slow down to the speed limit and shut the jammer off, the cop gets a tag on you. As long as your not doing stupid speeds this process will take seconds and nothing will be expected. Only when people purposely jam the gun as they drive past will they realise. Guns struggle to get a lock in some situations anyway so a few seconds to get a lock is nothing.
    11. #20
      Jun 2010
      N.Wales
      Black R300 + FQ340.
      Quote Originally Posted by AlC View Post
      That's why I don't use mine anymore. The amount of false alerts from automatic doors is unreal. That combined with the fact we don't tend to use mobile radar over here like they do in the US. Our radar is the fixed cameras and as you say, for laser the V1 is useless despite the fact it being one of the most sensitive detectors available. If you hear the laser warning, your being targetted.
      Bottom line is if you want to enure you don't get laser tickets, drive to the limit or get a diffuser.
