CV Joint - MeganeSport.net
    Page 1 of 6 123 ... LastLast
    Results 1 to 10 of 56
    Thread: CV Joint
      May 2007
      Nuneaton
      Default CV Joint
      Just got back from town with what sounds like a nacked CV joint.. horrid clicking from the drivers side when turning and accelerating
      In the past i remember some have tried replacing just the joint and not the whole shaft..are people still doing this? and if so can anyone get a Renault joint or is there a specific non oem one that has worked?
      Jul 2009
      Manchester
      225 F1 & 11 Kia Sportage
      Hi pal, there's a few of us suffering this problem. Is it a tick/click rather than a knock?
      If so, people have replaced the drive shaft and its not that, so hold off for now.
      Paul
      Jan 2013
      Chester
      Check the clip first, they are famous for snapping
    5. #4
      Jun 2013
      Ribble Valley
      was 172 ph1 | is R26
      As above, I wouldn't be so hasty to change the shaft as I have just done and it's made no difference at all to the noise.
      BTW the shafts are Renault only and I don't think you can get the CV joint separately. Most shafts you see are reconditioned ones.
    6. #5
      May 2007
      Nuneaton
      Hi guys, here's a vid of the sound I took last night..sorry about the quality
      https://www.youtube.com/watch?v=aP3a...e_gdata_player
      Ive not long done my hubs and the noise started not too long after lowering the car. the shaft came off when the hubs were done, and all the clips/boots looked all good and theres nothing else catching.
      I know you cant get just the joint from renault (grrr) but there has been people who have sourced and fitted joints only from what I can remember
      What does it sound like to you? It only does it when turning and accelerating im thinking its defo the joint
    7. #6
      Jun 2013
      Ribble Valley
      Video is private????
    8. #7
      May 2007
      Nuneaton
      Quote Originally Posted by Xanda73 View Post
      Fixed it
    9. #8
      Jun 2013
      Ribble Valley
      Ok seen it now.
      That's the same noise mine makes. I've replaced the whole drive shaft and its exactly the same, no difference at all.
      There does seem to be a lot of people with this issue and AFAIK nobody has found a solution.
      It drives me nuts and really doesn't inspire any confidence in the car. Every time I turn the wheel at slow speeds it makes me cringe and I find myself turning as little as possible to avoid it.
      Beginning to hate this car TBH.
    10. #9
      May 2007
      Nuneaton
      Ok seen it now.
      Exactly the same?
      Feel the same pal, just done a load of work and it still needs more. Im going to get it up on stands tomorrow to see where its coming from
    11. #10
      Jun 2013
      Ribble Valley
      Yeah sadly.
      I've had a good poke round mine and I've a little bit of play in the steering but not excessive but I don't think that's connected. Trouble with putting in on stands is the wheel/suspension drops down and isn't under any load so hard to replicate the noise.
