Adjustable camber arms - MeganeSport.net
    Page 1 of 2 12 LastLast
    Results 1 to 10 of 11
    Thread: Adjustable camber arms
      Jan 2011
      Getto De Kent
      225cup/566hp evo 6
      Default Adjustable camber arms
      Where is the best place for adjustable camber arms because I'm getting the car setup but the guy said there is not much adjustment with the standard setup on lowering springs
      Oct 2010
      Notts
      R26.R
      Don't think you can get them mate, never heard of them being available for the megane on standard suspension
      Feb 2008
      South east
      R26r + twingo
      You wont get any, need to go with coilovers with adjustable top mounts.
    5. #4
      Jan 2011
      Getto De Kent
      225cup/566hp evo 6
      So with my standard setup I'm not going to be able to get any sort of setup on that then
    6. #5
      Oct 2010
      Notts
      R26.R
      The only thing different from mine is that I have 6 minuites/ 1mm of toe out, give you a little sharper turn in , that's it untill I get some Coilovers fitted
    7. #6
      Mar 2010
      kent
      R26.R
      ASt's Steve ? : )
    8. #7
      Oct 2010
      Notts
      R26.R
      Not a chance
    9. #8
      Jan 2011
      Getto De Kent
      225cup/566hp evo 6
      What are the camber bolts like Worth a £20 buy ?
    10. #9
      Oct 2010
      Notts
      R26.R
      You can't get camber on a megane unless you use coilovers, but if you think you can for £20 mate good luck , let me know how you get on
    11. #10
      Apr 2013
      Glos
      I didnt think the camber bolts were compatible with the double-axis front strut suspension either, although i do see them advertised which is strange
