1 - 20 of 47 Posts
Right I'm on the look out for my next car and the 250 is topping my list
Spec wise I'm after the main 5 as i would see it
Vis pack
Recaros
climate
RS monitor
cup pack
seems like it could be doable for my budget of £17k max but willing to give up climate as a sacrifice but the other four are a must IMO
looking at PH's and Atrader theres a few out there but yellow seems to the most common colour and unfortunately its the one colour i don't want lol!
Looking at pics and spec sheets some seem confused as to what the cars have and don't have, I need to know the key tell tale signs of the different options, like i presume a car with Vis pack will have the black surround in the headlights? Is there a way of visually telling wether a car has the all important RS monitor is the dash different in anyway?
any help would be appreciated!
Yellow is the best colour for the 250 lol , non have the black headlights surrounds unless they ve been fitted after market
Hello mate, your best bet is to trawl the RS site which is quite concise with spec details;
http://www.renaultsport.co.uk/roadcars/megane250/Default.aspx
The headlights look a lot different when you compare xenon with the base spec ones though wouldn't say there was a black surround on the xenons, here's a photo of mine with them;
The RS Monitor is tricky to spot visually! You'll spot the satnav as its a nasty looking (IMO) square screen display on the top of the dash centre. The monitor screen is a lower curved affair in the same place but if the monitors not fitted or satnav the curved screen stays and is used for the radio/clock display.
Hope this helps!!
regarding the lights I'm referring to the inside of the light units they have a black plastic rather than silver, obviously the projectors also help but some photos its not that clear
for example
non xenon car
car with the vis pack
Xenon's have dark grey housing, Halogen have silver.
You can spot a cup pack easy enough as it will have red Brembo's
RS monitor is a hard one.
Recaro's and easy one
Climate has a different looking control face with no round knobs.
cheers andy does look a good un just don't think ill be able to knock £1k off the price but would depend on the trade in offer for my Mini GP
im also hoping that a capsicum Red one will pop up! fingers crossed
The only way to test for the RS monitor is to try to turn it on :)
Press the two triangular(ish) buttons on top of the control stalk on the right side of the wheel and the disclaimer should appear on the screen. RS Monitor functions are all in there.
Vis pack includes the DRL's and the Xenons, but the DRL's can be had seperately too. Best way to check is to look at the lights as mentioned above.
Cup cars all have red calipers. A full fat + cup with have leather seats and red brake calipers :)
is this theory true? if you have the monitor do you get renault sport on the radio display?
if you don't have the monitor you just get renault?
if you dont have the monitor the screen displays the radio info, if you turn the radio off you get the time and outside temp displayed.
Discussion Starter · #15 ·
Revive this if i can
can somebody list the spec difference between a bog standard CUP vs FF with Cup pack
after a quick search i managed to find
Cups lack the keyless entry and can't have climate control?
is there a difference in the interior quality like on the 200's i.e. worst steering wheel/cheaper plastics
tyre pressure monitor
tunepoint stereo
electric heated leather (only if you don't have recaros)
auto headlights and wipers
electrochrome rearview mirror
duel zone climate
hands free
interior is the same iirc except the seats are a different material and recaros are only material in cup can't have leather
without the monitor the screen just says renault when you get in the car
Discussion Starter · #17 ·
tunepoint stereo
duel zone climate
hands free
cheers for that mark much appreciated
Regarding this RS monitor, I've just rang up a dealership regarding a car and I'm unable to explain to the guy over the phone, how he will know if the Monitor is present as he is very unsure.
The jist is if the car has the monitor as soon has he steps in the car "Renaultsport" should appear on the screen if it doesnt then it has no monitor!
1 - 20 of 47 Posts
