1 - 12 of 12 Posts
Club Member
Can someone put a picture up of the air box mod please , minchy wants to see how it's done.
Cheers Steve
Wonder if this can be done on the dci 175 might have a look at the weekend....
So do you remove the feed permanently? Then could i run a cold air feed to it from the front grill?
On mine I've left the cylindrical tube in place so the air directs to the hole made.
Bet you could run a cold air feed to it but I doubt their would difference.
You can do it however you like mate. Space under the battery tray is limited though. The standard peice of pipe is around 65mm dia and there's not much space for a bigger ducting unless you compress it slightly. Yes, running a CAF would be a good idea, just be carefull where you place the feed incase it slurps up water.
Great i will have a butchers at the weekend as i have an itg filter to put in... Thanks for the info!
1 - 12 of 12 Posts
