Got the car back from the dealers today and all checks out on clip ok + they cleared the adaptive values.
I still cant rev over 6000 rpm properly when i should be able to hit 7200rpm. This is in addition to poor accelleration.
Do you guys think tightening the actuator arm would have caused this problem. I dont think its the exhaust's issue as it was happening before i had it done.
Injector has been swapped - Problem not solved
Adaptive values reset - Problem not solved
Coils have moved position - Problem not solved
Any ideas?
Any ideas?
