as above realy, still on the hunt for a re-map but one that has bin fully tested on a E4 engine,
paul how you getting on with it mate.?
then im 99% sure you will be in the same boat as me then matey, think all 55s are E4 engines.marccrocker said:Hi andy how can you tell if u have a euro4 motor.Iam wanting mine mapped.I have a 55 reg 225 MARC
no mate, from wat i can gather its not worth fitting it till the remap is sorted then run the two together, not sure if paul has sorted anything yet for a E4 engine.jonseal said:my service counter was 18k but other full fat phase 1 225s counted from 12k so i dont think the mileage indicator is a 100% way of identifying your engine type (also it can be changed by dealers on the CLIP before its delivered!)
Andy did you fit one of those apexi boost controllers? has that sorted out the boost for you?
paul have you got any further on the E4 front.RS-Tuning said:Renault really messed up with the service intervals on the meggy, to be honest i would NEVER leave a high performance engine to run 18k on the same oil, mine usually all get done at 6k as for the sake of oil and a filter it's not worth the wait.
As for the Euro4 it's quite a tricky one, what we found with Andys is that to bring the ignition on full we needed to have the car out of gear then press and hold the start button. This will probably (but not 100%) be a good test as on the Euro3 ECU this does not bring the full ignition on....
Paul
Pissed on my bonfire!Alex said:Paul,
ive got a euro 3 engine and if i put the card in the card reader and hold down the start button it puts the car into full ignition.
Most likely yes but..... The only way of knowing 100% would be to read the original.pt126 said:so my counter is 18000, m i good for the remap then?
