1 - 12 of 12 Posts
i had the battery disconnected today and after refitting it i get one beep when i lock the car and two beeps when i unlock it..
its the same tone as the beep what happens if your bonnets not shut right when you lock the car, a quiet but high pitch beep.
any ideas why it has started doing this
Supply on/off in quick succession turns the alarm arm/disarm beeps on an off. Loose connection as you reconnected the battery will have probably made the alarm change setting, disconnect and reconnect the battery again and it will turn off.
thanks guys, i'v disconnected and reconnected the battery and its now stopped :)
ian, open your bonnet and lock your car, that will set your alarm off, its not loud though, it certainly wouldn't wake me up through the night
mmmh, try and unlock the car using the emergency key, that should set it off
if not then your siren must me broke or disconnected.
1 - 12 of 12 Posts
