1 - 5 of 5 Posts
As above really, boot was temperamental opening for about a week and would open sometimes when the car was started. Won't open at all now. Questions: - how do I get it open and how do I fix it!!! R26 btw.
Ta
to open it go into the back of the car pull down the seat climb into the boot and look at the lock mechanism there is a small white release clip use a screwdriver and move it to the side it will release the boot. i had the same problem on my r27 changed the sensor was only £12 i think
dan
You have water in the boot release switch. Pop it out, disassemble and dry out. Mine had a split in the rubber cover, smeared some curing RTV silicone sealant over it job done. Or replace at around £30 new.
1 - 5 of 5 Posts
