1 - 19 of 19 Posts
Hi everyone!
The 4 pot brembo dust boot broken after 2 days of track activity:dazed002:
Did anyone know the diameter of the piston or the part no. of the repair kit?:baby[1]:
Hope somebody can share their experience for this, thank you.
I had the same problem on my rear brakes (dust boot broken) and my dealer ordered complete new brakes under warrenty (no discs offcource).
Discussion Starter · #4 · (Edited)
News from local Renault dealer, there's no rebuild kit (piston seal & dust boot) for our brembo caliper.
They quote me a new caliper instead which cost about 1,320USD for each.
Will try to knock Brembo dealer door to see whether they can help.
yep, i take to the dealer and told them that the car was vibrating while braking (didn´t say anything about bended disk...) and they told me the disk even had blue marks due to overheat them .... and that the garanty could not cover them...
had to buy new set of them...
I would have thought that should be covered under warrenty, I know it would not cover wear but damaged parts under use should be covered
Yeah, Same as Evo 8/9 IIRC
I have some waiting to rebuild my callipers for next year, Ill try get the part no. for you
If you speak to brembo directly I'm sure you can get some dust seals. There's no point buying a whole caliper when all you need is some little bits of rubber!
Jamie, what were the piston diameters if you dont mind me asking?
I have a dragging caliper and there's no rebuild kit available thru Renault. Is it 42mm for all 4 pistons or do we have a larger and smaller piston on each bank like most Brembos?
sadley you've been had buy your garage either through incompetence or just sheer stupidity, as said near impossible to warped disc, but pad build up on track day is very common and gives judder most folk think is warped disc. ive changed my brembo seals twice last year, after brutal heat applications in hot countries these kits are very good:
http://goo.gl/u0SBrO
1 - 19 of 19 Posts
