1 - 6 of 6 Posts
The tabs have broken on the silver plastic ring of the gear stick gaiter so now lifts right out. I ordered a new one from local Renault Dealer (£44) but on arrival the plastric ring is black and not silver!
After they called Renault they were told that this is the only one available. I am not sure which model has the black ring on the gaiter. If I am spending £44 then I at least want the right colour.
I think all Renaultsport models of that age had the silver one so would thought they would be still available to order.
Anyone tried to order one or know where I could get a second hand one from?
I had thought about glue, but waiting for an answer from Renault UK first as to whether it is definately obsolete.
Spotted this old post because I'm facing the same problem of the gaiter popping out when i engage reverse. Seems the top tab is the most stressed out of all the tabs.
How exactly do you use super glue to stick it? Do you apply the glue to just the tip of the broken tab?
1 - 6 of 6 Posts
