1 - 19 of 19 Posts
Hi all I'm new to the site. I'm wanting to bleed my clutch this weekend, done alot of research on here and other sites and iv seen the diagram posted by some one. I was wondering if you can use an easy bleed kit on them or not? Also a bit confused when it says use a syringe, not sure where this would go??
Any help would be greatly appreciated.
Thanks maz
you use the syringe to reverse bleed.
basically yes you should be ok bleeding as normal or a pressure bleeder as the slave is filled
people run in to problems when fitting a new clutch/slave
Thanks for the reply mate. No I'm not changing it just bleeding it, so it will be ok to use the pressure bleeder on it?
Thanks maz
While I was trying to bleed the system last night the pipe came past one click, does this need replacing now, or will it be ok?
When i did my clutch/flywheel/slave i was worried about bleeding the clutch from what iv read on here, got a mate to pump the pedal up firm, opened it up, he pumped away till ran clear, closed the nipple. had a good pedal, scratched my head and thought what was so hard about that lol
the only hard bit was the fact renault dont use a small nut/bleed nipple, but a stupid clip thing
Iv tried everything that's been suggest after reshearching and I still can't get it to work.
Yea mate peddle is dead, get it feeling something like then it goes again when I try to get it right
You are pumping the pedal up a good amount of times before you open the nipple?! Are you sure your not pulling the pipe too far off? This will cause air to enter the system again.
like jon35y said, its best bleeding it with 2 people, get someone to pump pedal up and down a good few times to create some pressure, have them hold pedal down and then open nipple and start pumping away keeping the resevoir topped up. Repeat until you ahve a clutch
unless seal has folded over in master cylinder?
Discussion Starter · #15 ·
It's no good mate, got it something like but can't get a full pedal, going to tow it to a Renault specialist I think
Oh dear oh dear tried just gravity bleeding down with one click.open or leading the pedal fully depressed overnight
Discussion Starter · #19 ·
I did the reverse bleed as well mate. Turns out the master cylinder and clutch peddle assembly were screwed. All sorted now. Thanks for the advice
1 - 19 of 19 Posts
