1 - 20 of 44 Posts
Hello everyone, I've done a bit of a search on this and found out a fair bit of info but i though i'de put up my unique situation lol.
I've just been for a spirited drive and all seems fine apart from 4th gear, As the car reaches peak torque at about 3000rpm the revs rise a little bit then fall to the normal revs, All other gears seem fine. Also my cars been remapped so if it is either of the clutch or flywheel, I suppose it would be a good idea to upgrade them, Any suggestions?
Any ideas what this could be?
Thanks in advance, I know it's probably been asked before :)
If you put the car in 5/6th at low revs then floor the throttle does it do the same?
Rs tuning helix clutch, flywheel, bearing and cylinder around £1440 fitted. Not cheap but Paul thinks the issues with the flywheel have been resolved by helix.
first sign of slip. could be eirther wont know till its all apart. im going for a r26.r clutch and fly
Could it be anything else that is causing it to slip? like a fault with pedal or cable?. I'm asking because my dad is having a look today to see if he can see any faults.
Sometimes a spring can pop out from behind the pedal. Have a search there's a picture on here somewhere. That's about it. The clutch is hydraulic.
Discussion Starter · #17 ·
Sorry to bring this back up but will i have any problems with the clutch and flywheel set up in the link on page 1?. I've been doing a search on here and well an trully baffled myself lol and scared myself to reading through loads of problems with the flywheel.
it will be the flywheel.
If you have a remote box,put the car back to standard,and I bet it will be fine.
If it was anything to do with the clutch pedal etc,it would do it all the time.
Discussion Starter · #19 ·
Yep just looked and the pedal and spring is fine :(, Unfortunetly i don't have a remote box.
I best ring up K-Tec lol
it's a pain,but as soon as you start going over 300 lb/ft ,the flywheel springs give in.
You could drive around for years with out changing it,just change your driving style, and only boot it once in a lower gear.
1 - 20 of 44 Posts
