1 - 18 of 18 Posts
I've just bought the pipercross induction kit for the Meg. On the web site they offered the cold air feed for about £30. I didn't bother purchasing it as I thought it was a bit expensive and probably wouldn't add much in the terms of power. Anyone got any thoughts on whether I made the right choice or where I can purchase the air feed cheaper?
Thanks,
Rob
iv run mine right down to the front grill, alot better induction if you ask me,
as for cost i got mine of ebay for for around £20 with a rubber funnel on the ends to sit behind the grill and into my viper still kit.
sounds great and looks great wen all on and done
Which size should the cold airfeed be?
I see that Pipercross offers airfeeds between 50 mm and 100 mm diameter.
Or can I put any?
Thanks Andy. What size diameter is your cold air feed?
Andy I have searched ebay for a cold air feed but cannot find anything else beside Pipercross (which is above 30 quids)
Do you have any clues where can I find something like yours?
If you don't have a proper cold air feed it will reduce performance as it did on mine so go the whole hog and put a cold air feed in!
I ran a cold air feed on my old car, it definately made a difference with the ITG filter.
I did find however if driving in rain the bottom of the panel filter became wet
so it would damage a standard paper filter i think
Phil
If you cut the bottom of the battery tray it doesn't get too squished.
Really trying to think of another way to get it in there (a bigger one)
Without the plastic engine cover you mean?
let me know and i'll go take one.
meggerman said:
andy is yours squished by the battery ?
hows about moving battery to boot *nose nose weight) and putting a semi open filter cone with custom feed from bumper ?? :idea:
did look at that idea but then its moving the ECU as the battery holds that in place, might have another look and see wat i can come up with,
also its knowing wat cable to run for the battery extension
I don't get it. It is just a tube made of plastic (or something like that). What do you mean by proper. I thought that any tube (same diameter) could do the trick... :roll:
Well i put an aftermarket induction kit on, with a tube in the same place as the standard cold air feed, and when the weather was hot it was majorly restricted, when it was cold weather it was amazing! Performance was great.
So it must be a cold air feed issue, once the pipe goes to the front bumper i'm sure it will make a big difference!
1 - 18 of 18 Posts
