1 - 7 of 7 Posts
Has anyone had a similar problem? Whilst driving all electrics cut out then come back on, last time it happened engine went as well not good whilst on motorway at night.
My dads scenic had this fault but this was due to the clock issue which they did a recall for. Could be a dodgy earth somewhere? If the engine mount are worn the excess rocking could losen the earth to the batter or cause damage to it.
I had this last year. Crank position sensor was the cause. Symptoms I had was engine would cut out. Display says engage neutral, interior lights come on. Then sometimes it would fire up straight away other times a few hours
Hope this helps.
Cheers lee
It came up with electrical fault, first time it happened was when I turned fog lights on and everything went off for a second apart from the engine, the only light that stays on is esp light on dash.
i had this recently, although it wasnt a complete electrical failure it stopped my engine from starting. Turned out to be an earthing problem somewhere in the engine wiring loom and it all had to be replaced at a cost of £650. Get in touch with renault uk if its low milage/newish car, they usually contribute towards the cost.
1 - 7 of 7 Posts
