1 - 20 of 21 Posts
Nail on the head Ben.
I think (after 6 months) I've sorted all the problems Renault caused... Apart from the occasional 'clunk' when going over bumps etc. but I've given up looking for it.
Give Renault customer services a call and see what they say. There's no way the gearbox should go at 33k miles and 3.5 years. I just had my windscreen wiper motor replaced out of warranty, all at Renault's expense. I know it's not quite the same, but they were very easy to deal with, and if you don't ask, you don't get...
Discussion Starter · #14 ·
Can't do anything with the engine on or off, clutch up or down.. Just neutral, it's seems to of got stiffer now though.. Somebody said the selector might have gone..
Always thought you would feel it for a while before a clutch/gearbox went.. It went from trying to get it in 6, down to 4 then wouldn't go in anything!!
Spoke to Renault 1st thing, need to get it to my local dealership for them to strip it down and find a problem
Might be worth taking the battery and battery tray out, disconnecting the cables from the box, making sure the cables are free and even seeing if you can select gears by moving the turret.
I'm sure the selector turret might is a couple of bolts on the top and one at the side.
Might even be a how to guide, as its the same part that everyone is changing to get a shorter gear shift :)
1 - 20 of 21 Posts
