1 - 11 of 11 Posts
You do, all RS Meganes have it!
There's a rocker switch below and to the right of the steering wheel, next to the headlamp levelling switch (if you don't have xenons) and the instrument brightness adjustment. One way is speed limiter, the other is cruise. You also have controls on the steering wheel to switch on and off and increase and decrease the speed.
There should be + and - signs on the steering wheel to the left and by the right side of the wheel about knee height there will be some switches.. If so, flick them and you should see a little green icon on the dash to say its active
Flick the switch up so cruise control is on the display press the plus button job done.
I think I read somewhere that Cruise Control won't work under 20mph - some kind of safety feature... So probably best to be going no slower than that to test if it works.
1 - 11 of 11 Posts
