1 - 12 of 12 Posts
I think the clip might have come loose on the pass side wheel CV joint as washing the car today the inside of the wheel appears to have grease all over it, its difficult to see on black alloys mind.
I wash the car most weekends and it wasn't there last week so has just happened
whats the best option? I know reno will tell me i need a new driveshift set up but if the boot isn't split could I refill with grease and get a new clip?
im sure others have had this issue just wondering where I can get the stuff to fix it and quickly??? so joint doesnt dry out!
will multi purpose grease do or is a high temp/ specialist one needed?
Thanks Dean
Yes its a problem , mine come off , took wheel and caliper off and fitted a new clip ,you can get little packets of cv grease
Ok thanks David, what type and size clip is needed? where did you get yours? would halfords sell them?!
at least it doesnt seem too difficult to fix caught early!
Local car spares do the cv 'clips' about £2 each plus a jar of black bearing grease is about £5.
If the boot is damaged Renault do a boot kit for around £30,don't be tempted to buy a cheap one from halfords or your local car spare. As I had loads of problems with mine,took ages to sort it out and wish I new Renault did the kit before I sorted the problem
Thanks for all the advice fellas.
Cheers Mark il need to take a closer look first just to check it has actually come off and not split, was going to do it today but never got chance!
if its damaged il buy the renault boot kit and get that fitted quickly!
Had a closer look at this, my cv boot is still intact and doesnt feel loose but the grease has come out, so looks like it needs re-clipping!
hopefully get it done before my MOT!
is there a specific size clip I need for the the megane?
I took mine to my mates garage and he did it for me for £20, its not worth getting your hands dirty for that.
If you get stuck Dean182 i can send you a new metal universal clip and grease....
But most good garages should have them but you will need special pliers to crimp it m8!
Dont not use cable tie as these are not strong enough to crimp the boot and will not last...
should be ok guys, the mechanic is going to do it before my MOT as the boot joint is intact shouldn't cost too much! better get it tested quick before something else breaks lol
1 - 12 of 12 Posts
