1 - 9 of 9 Posts
Just a quick question!!! How long does it take to fit a de cat? have searched on here but as im not a paid member at the moment cant see anything! thanks
fml! lol ok is there any reads on here that are a step by step guide of how to fit it? that i can read?
No "how to guide" but its a challenging job, if you dont have a ramp
Get the car at a decent height then mate and you might want a friend close by.
Remove:
Engine cover
Turbo heat shield
Lambda sensors or just unplug both of them.
Undo 3 bolts at turbo (usually stupidly tight)
Remove 8mm bolt holding cat to manifold ( very hard to see so might have to feel around)
remove drivers front wheel
REMOVE HUB NUT
Split track rod end from hub.
Undo the 3x13mm bolts holding wishbone to hub.
Remove vertical drop link
Remove engine under tray
Remove subframe crossmember
Undo driveshaft clamp
Remove driveshaft
Remove lower dog bone engine mount and all brackets attached to engine
Undo some 8mm bolts holding cat to engine, etc
Undo nuts holding cat to exhaust flexi part
Undo exhaust clamp and remove front pipe
Then it should be a lot of wiggling of the cat and a mate rocking the engine to give a bit more space.
Have fun!!!
oh boy! well my pal works for renault toomey as a spanner monkey guess i better ask him for some help!
Yeah, that might be a good idea mate......better have some beer tokens ready for your mate, as i think most companies charge around £200-300 to fit.
Man I was a bit surprised when my local specialist wanted £50 for a cat back but £200 with a decat. Now I'm starting to learn that it's actually a pretty good price for the whole lot. Why is everything on Renaults such a pain in the arse? lol
1 - 9 of 9 Posts
