1 - 7 of 7 Posts
Is there any difference or best way to do things when fitting a decat to keep the light off and stop the car going into limp mode? I'll get the map tweaked once it's fitted anyway so I can get the light mapped off then (If it comes on) but should I bother spacing the lambda anyway?
Cheers.
I thought that Mark but whilst it's off thought I could space it as it just depends how quickly I can get to RST once it's all fitted. Cheers Lemon. I thought it did so not too bad then If you only get the light.
I can reset the light for you until you get it mapped , although light won't put it into limp!
A lambda extender is around £15 ish
I thought it would go into limp mode but I could live with the light. Mite just get a spacer on anyway If there only like £15.
1 - 7 of 7 Posts
