1 - 8 of 8 Posts
Just found them, Denso Iridium Ik20. 14mm thread, thread reach, 19mm, hex nut size 16mm. On eBay for under £40 Genuine.
I had same warning on my focus st but they were fine, but not changed them in the Renault, so what would be a good replacement?:scooter:
A sad little tip...but you will all understand !!
We run race bikes on the dyno a lot and set them up....when you fit your plugs face the open end of the tip toward the inlet valves...on an R6 we see over half a horsepower increase everytime (the mix flow is not disrupted by the tip pillar before it gets to the spark)...Ok I know its anal and sad but it makes you feel good in that we do all we can...and as tesco says 'every little helps'
1 - 8 of 8 Posts
