1 - 4 of 4 Posts
Hey guys i jus got my dump valve kit from jon and i have the silicon T piece, the valve, rubber hose, round metal plate? and some clips. Anyone tell me what the round metal plate is for? and does it fit just like the one in the guide? if not anyone help :) cheers.
Hello mate, the round plate is a blanking plate for if you require to remove the valve but leave the pipe in place. The guide should be fine for fitting. If you are stuck you basically need to loacte the small vacuum hose which connects to the std. recirc valve and insert the T there.
Paul
cheers mate, it also came with 2 small t-pieces and 1 piece thats round with a pipe through it, any idea what thats for? do i just use the jubilee clips from the standard pipe?
So basically -
Valve goes on top of silicone tpiece and jubilee tightened
placed in bay where standard pipe was and jubilee clipped in
hose run to rec pipe and tpieced in with the small tpiece
Done
left with one small tpiece spare and the other bit mentioned.
That right? cheers mate.
1 - 4 of 4 Posts
