Status
Not open for further replies.
1 - 8 of 8 Posts
Do you remember the product code of Ferodo DS 2500 for RS 250 Cup (front brakes)?
I think it is FCP1334H.
Can you check it out please?
Thanks!
I'll check for you shortly, I have a set for my GTA, which takes the same pads.
The number you say rings a bell though, the last letter is the compound, so ds3000 just differs by a character.
The DS2500s will be a slight improvement over standard, which I personally believe are Ferodo DS-perfs.
Cheers, TB
Yup you were correct.
FCP1334H are front DS2500s
Swop the H for an R and you get DS3000
Swop the H for an M and you get DS3000+
If you leave out the Last letter (i.e the H) entirely I think you just get standard DS-perf road pads, the other letters I am certain of.
Also, in case you spot a bargain somewhere FCP3067H pads can also be used, just a mm thinner or so, but same shape. The H implies Ds2500s as above.
Can't find the pads on jjcraceandrally or demon tweeks, filter not searching anything for the rs250. I typed the code into eBay and they come up for the Alfa Romeo 166 & 147.
I take it the Alfa and rs250 use the same pads?? So I can order they ones??
1 - 8 of 8 Posts
Status
