1 - 7 of 7 Posts
just wondering if my forge dump valve from k tec should be letting pressure out even when driving normal seems to go off even at low revs cheers.
Mine used to do this. I fitted a blue spring and it solved the issue.
K-tec kits are single piston and i find them a bit more sensitive to throttle postion changes.
Hi, I had the same problem fella got mine from K-TEC to. They told me I should of had a twin piston, they kindly swapped it over and hey presto no problems at all, hope this helps
Got the spring kit from forge motorsport. Check there website for the kit, its not that expensive and really easy to change the spring.
cheers bud just ordered one did you notice a difference in boost now that less pressure is released
1 - 7 of 7 Posts
