1 - 4 of 4 Posts
I've took my forge recirc apart to service but I can't remember the orientaion to put it back together again. Where does the nipple on the front plate point in relation to the cemi circle on the bottom of the valve or does it not matter?
You should be a tech mod B ;)
Don't suppose you can remember where the opening sits on the turbo? I'll try assemble it like the OE recirc layout.
I can't remember where the pipe comes from that goes onto the nipple but I don't want to inadvertently have it on the opposite side to where the pipe comes from, Even If it will only look ****.
1 - 4 of 4 Posts
