Spoke to Renault today they have found the problem after stripping the box..
The problem is between 5th and 6th something to do with the synchro.. Now if that's broken surely I should of been able to select 1st 2nd 3rd 4th??
The best is yet to come, asking what could of caused this problem, they told me I have been forcing it it to 5th or 6th gear, Causing the damaged!!
I have explained before what happened, but will refresh: driving along in 5th, clutch down to go into 6th wouldn't select(felt really stiff), so back into 5th, slowed down a little and dropped it into 4th(no problem), so tried 5th which now felt the same as 6th(jammed) back into 4th which has now also jammed.. Every gear is now jammed and can only move the gear stick left to right!!
A little force was used when I couldn't select 5th, but with the clutch down and I think anybody else would do the same!!
Renault have now taken pictures and Have sent them down to there warranty department to look over!!
I feel that Renault are massively trying to pull a fast 1 and there's **** all I can do about it!!
