1 - 12 of 12 Posts
Fault keeps appearing throttle actuator and does not rev over 2.5 rpm ..... If i change the throttle body will this let the car rev as normal????
Remove the hose before the throttle body or dump valve if fitted and inspect the piping. I had the metal insert that sits inside the plastic side come loose and move across and half block the throttle body and it gave similar faults.
Could be a body or could be a pedal needs a decent diag first before you jump in change parts. A throttle body is £300 for example so you need to be sure!
Try cleaning the Throttle actuator.
Remove the rubber hose in front of it, turn the ignition on and get some to step on the gas pedal from so you can check. Or start the car withought the hose and get someone to rev it in neutral.
1 - 12 of 12 Posts
