right guys I've had an issue for a couple if months now where I am getting a slight hesitation/misfire, this normally happens between 2-3k revs and never happens above 4k, it is always worse when the engine is cold as it will miss in every gear up to 3k.
if you go through the gears properly to 6-7k and then change you don't get the problem you only get it when you put your foot down in a higher gear at lower revs.
I have changed the plugs and coils now both with genuine Renault spares as I was convinced it was an related problem.
the car has never registered any fault codes with this problem either, anyone able to offer any pearls of wisdom please
