1 - 3 of 3 Posts
Ok so got more problems with the 225. Start the car and it sits at 2,000rpm and let's you rev upto 4,000rpm then bounces like its on a limiter. Turn the throttle body actuator(little knob thing on throttle body) down and it idles at 900rpm like normal but there's no throttle response.
2 faults are throttle body actuator and super boost sensor malfunction (roughly)
All pipes are on. None split and the pipe on the top of the throttle body is securely tied down
Any ideas what the problem is?
Discussion Starter · #2 ·
Oh and my mate ****ed about with the turbo actuator when I was at work cause midland turbo had turned it back down when they rebuilt the turbo. so I made him turn it back down. Probably a good chance he turned it down too much. What problems would this cause? Thanks
What diag gear do you have access to? Its going to be either the body or the pedal, sounds like its in defect mode as it stands or the body is just rodgered. If you haven't got any decent diag gear avaliable then pick a throttle body up off ebay and try that.
1 - 3 of 3 Posts
