Guest
·I have a new noise, it sounds like a wheel bearing about to get worse but my back brakes are real noisy at the minute.
Has anyone had problems with either?
Rossy
Rossy
Definetly check the condition of the pads mate as Phil says.phil said:if its any help the back brakes seems to wear uneven as in the
inside pad wears more than the outside pad
Depending on your mileage they may need changing
phil
i had it, it comes from the rear right wheel, ???theboyrossy said:I have a new noise, it sounds like a wheel bearing about to get worse but my back brakes are real noisy at the minute.
Rossy
now ine is all stripped out in the rear its realy loud and the noise is easy to spot, but i put it down to the discs being vented and drilled as i only get the noise wen on the brakes or going round a right hand bend hard.CHRISTOS said:is it a sort of roaring noise? Mine does it sometimes thought it was comming from the rear left wheel aint had it looked at yet
exact the same as mine, 100% the rear discs working as the air flows through them, and mine gets better and less noise the more miles i do to.CHRISTOS said:I seem to get the noise only on certain roads when it leans to one side. Might have to get it checked out.
