Just thought id let you know about something i found out on my car when i had it in for a service.
Webcode is probably fully aware of this one.
Basically if one of your front indicators appears to have stopped working dont swap the bulb out straight away. \the indicator will start flashing as normal for 2 flashes then flash like a bitch ..... well like one of those clapped out cars you see.
There is a known issue where the housing dosent sit correctly and seems to move a little. There is a arc of some nature when the bulb flashes but when the housing is out of position it dosent make this connection.
I would recommend taking the car into the dealer if you get this as the housing is a known issue and is covered under warranty. The guys at london west said they wee several of these in a week.
Alex
Alex
