As blackcup says, try the key in the slot + start it up, take it out and hopefully it'll lock n fold as you walk away then unlock as you walk back upto it! Fingers crossed.ok did a car battery disconnect reset and everything works properly now except for keyless entry. car locks when i walk away but wont unlock even when i pull the door handle. the only way to unlock the car is press unlock on the keycard.
redd
As above. When you change the keycard batteries in the Megane 3 you need to start the car up with the key in,turn the engine off,take the key out and it will auto lock on its own as you walk away.As blackcup says, try the key in the slot + start it up, take it out and hopefully it'll lock n fold as you walk away then unlock as you walk back upto it! Fingers crossed.
