just 1 question why would you want to put different springs if you have a cup pack fitted????
Approximately i think! althought the cup owners might disagree!ray225 said:is the cup 30mm lower than the standed one??
Revalved? whats that then?rg225 said:I ve done mine as well i have used the same eibach's as Phil's but i changed the struts to the cup/trophy spec ones which are revalved compaired to the full fat ones.
Richard 8)
if you got one or getting one with a cup pack you cant lower it matey, as the springs from k-tec will only fit a full fat 225 to lower it to a cup ride height.ray225 said:so if i do go ahead with the springs does it sit lower than the cup? or are thay the same?
you can lower a cup lower. fit coilovers for a startandy bassett said:if you got one or getting one with a cup pack you cant lower it matey, as the springs from k-tec will only fit a full fat 225 to lower it to a cup ride height.ray225 said:so if i do go ahead with the springs does it sit lower than the cup? or are thay the same?
so in short you can not lower a cup any lower.
yes you can but he was asking about the eibach springs from k-tecmeggerman said:you can lower a cup lower. fit coilovers for a startandy bassett said:if you got one or getting one with a cup pack you cant lower it matey, as the springs from k-tec will only fit a full fat 225 to lower it to a cup ride height.ray225 said:so if i do go ahead with the springs does it sit lower than the cup? or are thay the same?
