1 - 11 of 11 Posts
I have the std seats with the lever on the left of the Drivers seat to adjust the lumbar support
It still adjusts but within minutes it has slipped back.
I have popped the lever off but it just clips to a plastic rod.
No clues how to'stiffen' it up.
Any ideas anyone in how to stop this please?
Cheers Andy
Hi Andy.
It's been along time. The lever splits very easily and looses strength. I would mention it to your dealer to see if it can be changed. If you need any help, just let me know.
Andy C
Hi Andy and Nig63.
I moved to the dark side for a while, but am back now. There is a fix for the lumbar support available from your local dealer. Renault are aware of this issue. Any probs, let me know.
Andy
Hi Andy.
No luck at the dealers they have no knowledge of a 'fix' and could not find any info.
Is it a local thing or have you a ref/bulletin or whatever or details of what to do for me [them!!]
Cheers Andy
Hi Andy.
Wests managed to find the fix, although it seems abit crued. I will get it emailed over to me and I will post it later for you.
Andy c
Hi Andy.
As promised please find the following solution offered by Renault Technical..........
Solution specifications :
Solution n°:
8 606
Creation date:
19/11/2010
Start of Manufacturing Date
28/09/2009
Technical note
Monitoring code:
Solution not followed by TN
Update:
19/11/2010
End of Manufacturing Date
16/09/2010
Customer complaint:
The driver's seat lumbar adjustment handle does not stay in position.
Recommended solution:
POSSIBLE CAUSE: The locking lugs for the blanking cover on the lumbar adjustment handle do not work properly.
DIAGNOSTIC: Visual. The blanking cover does not stay in position.
AFTER SALES SOLUTION: Cut a strip of self-adhesive felt (1) (see attached photo) measuring 25 mm X 10 mm from part no. 8200281967. Position the strip of self-adhesive felt (1) on the external face [A] of the blanking cover lock, opposite the locking tab .
PRODUCTION SOLUTION: Production process improved since 16/09/2010.
Additional details:
8606_document.pdf
Model involved
Assembly plant
MEGANE III
DOUAI
MEGANE III
PALENCIA
Engine: type
Engine: index
First production number
End production number
Gearboxes: type
Gearboxes: index
Battery type
Battery suffix
AFR/LUP no.
QX95022342
ECR
Incident type involved
1350
Seats : Front seats: Defective trim
1370
Seats : Front seats: Comfort/Support
1372
Seats : Manual front seats: Operation
1 - 11 of 11 Posts
