Guest
·Today I took my 225 meggy to my Dixon Huddersfield Renault stealer. I took the list below nicely printed in Times New Roman 14. Lets see to how many of the faults the respond "Computer Says No..."
1. Over sensitive throttle pedal from idle: It makes declutching from 1st gear quite difficult (it over-revs too easily) It seems that the engine revs disproportionately in relation to the throttle pedal travel. You end up burning the clutch to get moving smoothly. The car has suffered from this since new but I assumed it was a design flaw until I drove two other 225s without the problem.
2. Hesitation under hard acceleration: On a recent trip to the coast I had to pull over to the hard shoulder. In order not to disrupt the traffic when coming out again, I had to accelerate quite quickly. At around 5000rpms in 1st the car stuttered and then continued to accelerate. After that incident, the Check Engine icon lit up for the rest of the journey.
3. Rattle coming from underneath the front: I have brought the car to your garage before to sort this out but without luck. I was told that even though you could hear the noise, you could not locate it and I should bring it back if it did not go away. It hasnt. It is not a heavy clonking type noise when braking or steering but more of a light rattle when driving over rough surfaces such as broken roads or cobble stones. I cannot tell if it comes from the suspension or brake assembly but it seems to come from the front end of the car. Need to listen to it with the windows open. Go to the St. Andrews Road car park (Behind Sainsburys), it has a cobble stone path right from the entrance.
4. The Auto function on the climate control unit does not seem to respond properly: In cold mornings (0 5 degrees Celsius outside) I set the unit to max temperature in Auto mode but it does not blow any air (neither hot nor cold) from any of the vents. Same thing in warmer days, when the unit is set to a cold temperature (15 degrees for example) and in Auto mode, no air seems to come out neither from the windscreen, dashboard or lower vents. Only when I turn up the fan speed manually (and the fan icon appears and the AUTO icon disappears) is that I get warm (or cool) air blowing through the vents
5. Front right tyre looses pressure
If any of you can "relate" to these problems... Feel free to share the luv... :roll:
